Can A Philco 90 Be Modified to receive a frequency of 1540KC
Thanks Brian,
I had considered something similar to your suggestion but that mellow and certain tone quality of yesterday's tube radio sound would be lost. I appreciate you sharing your thoughts and ideas.
Regards,
Floyd
The speaker table error?
Philco 70 antenna lead
