E.H. Scott Power Amp Supply Chassis - NEED HELP w/ ID
Not an amp but a power supply, a robust one indeed...
May have had a problem in the past, the black painted transformer does not appear to be OEM, if it is correct is another guess...
Pliny the younger
RE: E.H. Scott Power Amp Supply Chassis - NEED HELP w/ ID - by Chas - 05-20-2022, 07:10 PM
