PHilco 44
No, sorry, no pictures of chassis'.
But you can use the TUBE MANUAL section of my website to help identify the chassis you have. Use the tube socket layout diagrams there to see what matches the tubes and locations on the chassis.
PHilco 44 - by Mauricio - 04-26-2006, 04:40 PM
[No subject] - by Chuck Schwark - 04-26-2006, 08:16 PM
philco 44 - by Mauricio - 04-27-2006, 01:42 AM
[No subject] - by Chuck Schwark - 04-27-2006, 09:17 AM
picture of chassis 44B - by Mauricio - 04-27-2006, 05:15 PM
[No subject] - by Chuck Schwark - 04-27-2006, 05:29 PM
philco 34b baby grand - by Mauricio - 04-27-2006, 05:38 PM
[No subject] - by Chuck Schwark - 04-27-2006, 07:39 PM
Can send pic via email - by AI2V - 04-30-2006, 06:27 PM
Philco 91 Tuning Condenser
