Hooray! I Finally Got a 'BIG DOG' Philco
Wow, that is the cat's pajamas and meow in one. Nice clean chassis to work with too. The cabinet looks great as is.
A clean and polish should make it a show piece.
There are currently 8557 online users. [Complete List]
» 1 Member(s) | 8556 Guest(s)
