First attempt at rewinding an oscillator coil (Phil 38-12)
Steve Davis Wrote:
Art Hoch Wrote:2nd try today:
I reversed the connections to adjust for a different winding direction....same result.
Art, when you say you reversed the connections, did you reverse the connections on both windings? If so, that would not change the relationship between the windings. You would want to reverse the connection on only one winding.
Yes, I reversed both. Does it matter which one? Have to leave it lay for a couple days. Will try again later.
Art
Re: First attempt at rewinding an oscillator coil (Phil 38-1 - by Art Hoch - 05-12-2011, 10:47 PM
The speaker table error?
Philco 70 antenna lead
