Atwater Kent 82, restoration.
Today I decided to take it on the condensor cans. I picked the first one, with the caps 13-16.
In fact, in the sch and on the chassis drawing the can has 4 caps; in reality it has 5 caps as the tone control switch uses 3 of them, and not 2 and one empty position, like the sch shows.
Here's the can in city.
I took the drill and drilled out the rivets.
The desoldered it.
Then I set my sodering iron tip temerature to just ove 800F.
The tin is rather thin, and so I kept heating the bead and shaking the solder off.
Then I pryed the lid and with a little help of soldering iron it came off fairly easily.
Then I heated the eyelets and shook out the solder to free the wires.
Also the solder bead on the side. I did not know whether it held the ground wire. So I desoldered it just in case.
With a bit of prying, some sort of cover came off, and then the innards.
The other side of the cover had some numbers on it; I wonder if it is the can P/N.
Would like to finsd out to figure the 3rd Tone ctl cap's value. Though I am sure it is small, 300-500pF, and not too important.
Some info on AK is here. But I need more.
http://www.atwaterkent.info/TechData/Ima...32_018.gif
http://www.atwaterkent.info/TechData/Ima...32_019.gif
It says the block number is 21250.
The Gernsback book gives the values of 21250 (with the exact confuguration as mine) as 500pF - 3nF - 7nF. The values are a tad different from what sch shows. But I will trust the description in these books, seem legit.
https://worldradiohistory.com/BOOKSHELF-...Supl-6.pdf
Atwater Kent 82, restoration. - by morzh - 05-22-2022, 06:10 PM
RE: Atwater Kent 82, restoration. - by Jayce - 05-22-2022, 07:29 PM
RE: Atwater Kent 82, restoration. - by morzh - 05-22-2022, 08:45 PM
RE: Atwater Kent 82, restoration. - by Jayce - 05-22-2022, 10:12 PM
RE: Atwater Kent 82, restoration. - by morzh - 05-22-2022, 10:56 PM
RE: Atwater Kent 82, restoration. - by Jayce - 05-23-2022, 11:19 AM
RE: Atwater Kent 82, restoration. - by morzh - 05-23-2022, 09:30 PM
RE: Atwater Kent 82, restoration. - by Eliot Ness - 05-24-2022, 10:04 AM
RE: Atwater Kent 82, restoration. - by Chas - 05-24-2022, 10:22 AM
RE: Atwater Kent 82, restoration. - by morzh - 05-24-2022, 11:51 AM
RE: Atwater Kent 82, restoration. - by Arran - 05-25-2022, 02:27 AM
RE: Atwater Kent 82, restoration. - by morzh - 05-25-2022, 09:57 PM
RE: Atwater Kent 82, restoration. - by morzh - 05-28-2022, 09:15 PM
RE: Atwater Kent 82, restoration. - by RodB - 05-28-2022, 10:41 PM
RE: Atwater Kent 82, restoration. - by radiorich - 05-28-2022, 10:53 PM
RE: Atwater Kent 82, restoration. - by morzh - 05-29-2022, 12:09 PM
RE: Atwater Kent 82, restoration. - by radiorich - 05-29-2022, 12:56 PM
RE: Atwater Kent 82, restoration. - by morzh - 05-29-2022, 03:37 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-04-2022, 08:49 PM
RE: Atwater Kent 82, restoration. - by radiorich - 06-05-2022, 12:13 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-05-2022, 12:24 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-05-2022, 01:16 PM
RE: Atwater Kent 82, restoration. - by Eliot Ness - 06-05-2022, 01:43 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-05-2022, 03:17 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-05-2022, 08:58 PM
RE: Atwater Kent 82, restoration. - by radiorich - 06-06-2022, 01:25 AM
RE: Atwater Kent 82, restoration. - by morzh - 06-06-2022, 10:06 AM
RE: Atwater Kent 82, restoration. - by radiorich - 06-06-2022, 08:25 PM
RE: Atwater Kent 82, restoration. - by radiorich - 06-06-2022, 08:26 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-06-2022, 10:42 PM
RE: Atwater Kent 82, restoration. - by radiorich - 06-06-2022, 11:37 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-06-2022, 11:46 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-09-2022, 12:29 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-09-2022, 01:32 PM
RE: Atwater Kent 82, restoration. - by rfeenstra - 06-09-2022, 06:54 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-12-2022, 10:50 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-14-2022, 10:44 PM
RE: Atwater Kent 82, restoration. - by radiorich - 06-14-2022, 11:45 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-18-2022, 10:35 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-19-2022, 06:19 PM
RE: Atwater Kent 82, restoration. - by morzh - 07-02-2022, 07:06 PM
RE: Atwater Kent 82, restoration. - by morzh - 07-04-2022, 12:18 PM
RE: Atwater Kent 82, restoration. - by morzh - 07-04-2022, 02:40 PM
RE: Atwater Kent 82, restoration. - by morzh - 07-09-2022, 02:31 PM
RE: Atwater Kent 82, restoration. - by RodB - 07-09-2022, 03:27 PM
RE: Atwater Kent 82, restoration. - by morzh - 07-09-2022, 05:29 PM
RE: Atwater Kent 82, restoration. - by RodB - 07-09-2022, 06:34 PM
RE: Atwater Kent 82, restoration. - by morzh - 07-10-2022, 01:34 PM
RE: Atwater Kent 82, restoration. - by morzh - 07-11-2022, 09:13 PM
RE: Atwater Kent 82, restoration. - by morzh - 07-12-2022, 10:55 PM
RE: Atwater Kent 82, restoration. - by RodB - 07-13-2022, 10:24 AM
RE: Atwater Kent 82, restoration. - by morzh - 07-13-2022, 11:03 AM
RE: Atwater Kent 82, restoration. - by RodB - 07-13-2022, 12:44 PM
RE: Atwater Kent 82, restoration. - by morzh - 07-13-2022, 03:47 PM
RE: Atwater Kent 82, restoration. - by morzh - 07-13-2022, 09:02 PM
RE: Atwater Kent 82, restoration. - by GarySP - 07-13-2022, 09:30 PM
RE: Atwater Kent 82, restoration. - by morzh - 07-13-2022, 09:42 PM
RE: Atwater Kent 82, restoration. - by tbone - 07-14-2022, 07:08 AM
RE: Atwater Kent 82, restoration. - by PhilcoJohn - 07-14-2022, 07:42 AM
RE: Atwater Kent 82, restoration. - by RodB - 07-14-2022, 08:33 AM
RE: Atwater Kent 82, restoration. - by Eliot Ness - 07-14-2022, 06:27 PM
RE: Atwater Kent 82, restoration. - by GarySP - 07-15-2022, 09:08 AM
RE: Atwater Kent 82, restoration. - by morzh - 07-15-2022, 11:48 PM
RE: Atwater Kent 82, restoration. - by MrFixr55 - 07-16-2022, 11:23 AM
RE: Atwater Kent 82, restoration. - by morzh - 07-16-2022, 12:45 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 8250 online users. [Complete List]
» 1 Member(s) | 8249 Guest(s)
