Atwater Kent 82, restoration.
Threads: 562
Slowly.
I need to rebuild the rest of the cans (3 left).
Also need to decide if I am rebuilding the elecytrolytics. There is a chance I will simply relace the Philco Ford caps mount on soldering lugs, using the lytics as mounting posts.
During working days I am not doing much of it. Well, I have soldered the rebuilt can back. That counts for some activity
RE: Atwater Kent 82, restoration. - by morzh - 06-06-2022, 10:42 PM
Hello Tim,
Hello Tim,
Hi Dan,
Hello Tim,
bk1077bradiorich — 09:01 PM |
