  • 1 Vote(s) - 3 Average
Atwater-Kent Original Service Data
I am moving right along with the scanning. It takes about 4 - 5 minutes a page to scan and process and save as a JPG. Today I did 64 pages. I found 4 pages missing from the book. They had been cut out at some point. I copied the information on the missing models from Rider's and made substitute pages.
For those wondering, my scanner is an Epson Perfection V550 Photo. It will scan slides and negatives as well as the usual flatbed stuff, so it can take the place of an enlarger to make prints from old negatives, and can digitize them and old color slides. All of my scans of the manual are being done at 600 DPI, and that is giving very good, clear results, allowing easy reading of even the tiny print.
RE: Atwater-Kent Original Service Data - by mikethedruid - 06-07-2022, 12:55 AM
RE: Atwater-Kent Original Service Data - by RodB - 06-11-2022, 08:47 AM
RE: Atwater-Kent Original Service Data - by RodB - 06-18-2022, 08:16 PM
RE: Atwater-Kent Original Service Data - by RodB - 06-19-2022, 08:44 AM
