  • 1 Vote(s) - 3 Average
Atwater-Kent Original Service Data
The re-scans are done. This project was a LOT of work, but, being retired, I just went at it as if it was a working task, and kept plugging along until it was all done. Having a very good scanner helped a LOT. Now I just have to wait for the SD cards to arrive. I may buy some thumb drives too, and distribute that on that format too.
RE: Atwater-Kent Original Service Data - by RodB - 06-11-2022, 08:47 AM
RE: Atwater-Kent Original Service Data - by mikethedruid - 06-15-2022, 03:50 AM
RE: Atwater-Kent Original Service Data - by RodB - 06-18-2022, 08:16 PM
RE: Atwater-Kent Original Service Data - by RodB - 06-19-2022, 08:44 AM
There are currently 10595 online users. [Complete List]
» 2 Member(s) | 10593 Guest(s)
