Shadow Meter Coil Resistance On 37-650
Pepperoni Wrote:My first experience with a shadow meter. In fact I still don't know what it does or how it works. I know that something is adjustable on the coil section that moves a small piece inside the housing but that's about all I know at this time.
John
Check this site, I haven't read it all yet but it explains how the Shadow Meter works.
http://www.philcorepairbench.com/tips/svctip01a.htm
-Keith
Re: Shadow Meter Coil Resistance On 37-650 - by ipwizard - 05-14-2011, 03:12 PM
The speaker table error?
Philco 70 antenna lead
