Zenith 5-S-119
I've been following the one you're referring to on a Canadian Auction site. A bit of a Frankenradio. Too bad that the correct speaker and plug are missing and the hand written band position markings may be difficult to remove. I think this could be a great project but for me, the current high bid is too much for this one.
Jim
Zenith 5-S-119 - by GRG - 06-21-2022, 09:57 AM
RE: Zenith 5-S-119 - by Eliot Ness - 06-21-2022, 12:54 PM
RE: Zenith 5-S-119 - by GRG - 06-21-2022, 05:15 PM
RE: Zenith 5-S-119 - by JimSirt - 06-22-2022, 12:07 PM
