Opinions: Grill Cloth for 37-116 & 116B & 16B
Think the set that uses the most is the 201X. Center section is 14"w x 23"L and two pieces 7"w x 22"L. But back to the question at hand.
1934 16B peaked top
10 3/4"w x 14"L
The 1936 116B early is pretty much the same size. The late '36 is smaller.
116X
12"w x 24"L center section and two 10"x10" for clairifers.
37-116X
18" w x 24" L center section and two 10"x10" for clairifers.
These are hard to measure as they are covered by another board that the speaker is mounted to. Can't really see it.
Generally these measurements are edge to edge.
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 8500 online users. [Complete List]
» 2 Member(s) | 8498 Guest(s)
