Opinions: Grill Cloth for 37-116 & 116B & 16B
Thanks, guys. I'm sure Michael will appreciate this info.
I suspected the 37-116 would require the widest cloth (plus the two smaller pieces for the two acoustic clarifier openings).
I will try to measure my 37-675 tomorrow, as well as my peaked top 16B tombstone.
radiorich Wrote:is that cloth used in Philco 610b I can see what size mine used.
No, the 610B used the 1935-36 Philco diamond pattern.
https://philcoradio.com/gallery2/1936a/#Model_610B
