Model 39B
Nice! That is essentially a DC powered model 66. You have a fairly broad shortwave band on that set. Definitely a keeper!!
Model 39B - by 37silverstreak - 05-15-2011, 08:35 PM
Re: Model 39B - by Ron Ramirez - 05-15-2011, 08:44 PM
Re: Model 39B - by TA Forbes - 05-15-2011, 09:06 PM
There are currently 10178 online users. [Complete List]
» 2 Member(s) | 10176 Guest(s)
