I NOW OWN A BOAT ANCHOR???
David - Thanks for the information. I had seen the Phorum thread, but not the second thread - very helpful.
Ron - Thanks for the advice. I had intended to polarize the set when I replaced the power cord. After switching the hot side, would I be able to install .01 Y2 line caps to eliminate the need for an attached external ground? I'm gonna pester a lot of you learning with this set! Please forgive me.
Mike - Warning heeded! 14 x 8 x 8.5 inch cabinet and 22 pounds!
Had an unexpected bonus so far. Inside the radio was a magnetic mechanical pencil, still filled with lead! No markings on it, and only about 4 inches in length.
The radio is painted grey crackle coat. There are a few areas with slight paint flaking. My plan was to gently wash the cabinet with soap and water, then leave it in the sun to dry. Once dry, I was considering giving it a coat of matte finish clear to re-fix the flaking paint. I'm not a finish expert either, so let me know if this is what should be done.
Take care, and BE HEALTHY! Gary
I NOW OWN A BOAT ANCHOR??? - by GarySP - 07-09-2022, 10:25 AM
RE: I NOW OWN A BOAT ANCHOR??? - by morzh - 07-09-2022, 11:41 AM
RE: I NOW OWN A BOAT ANCHOR??? - by David - 07-09-2022, 12:16 PM
RE: I NOW OWN A BOAT ANCHOR??? - by Ron Ramirez - 07-09-2022, 12:47 PM
RE: I NOW OWN A BOAT ANCHOR??? - by GarySP - 07-09-2022, 01:48 PM
RE: I NOW OWN A BOAT ANCHOR??? - by RodB - 07-09-2022, 03:01 PM
RE: I NOW OWN A BOAT ANCHOR??? - by Ron Ramirez - 07-09-2022, 03:32 PM
RE: I NOW OWN A BOAT ANCHOR??? - by GarySP - 07-09-2022, 09:49 PM
RE: I NOW OWN A BOAT ANCHOR??? - by mikethedruid - 07-10-2022, 12:08 AM
RE: I NOW OWN A BOAT ANCHOR??? - by Ron Ramirez - 07-10-2022, 07:38 AM
RE: I NOW OWN A BOAT ANCHOR??? - by GarySP - 07-10-2022, 11:00 AM
RE: I NOW OWN A BOAT ANCHOR??? - by GarySP - 07-10-2022, 11:08 AM
RE: I NOW OWN A BOAT ANCHOR??? - by Chas - 07-10-2022, 12:18 PM
RE: I NOW OWN A BOAT ANCHOR??? - by GarySP - 07-10-2022, 12:49 PM
RE: I NOW OWN A BOAT ANCHOR??? - by Jayce - 07-10-2022, 01:02 PM
RE: I NOW OWN A BOAT ANCHOR??? - by MrFixr55 - 07-10-2022, 03:35 PM
RE: I NOW OWN A BOAT ANCHOR??? - by Ron Ramirez - 07-10-2022, 06:24 PM
RE: I NOW OWN A BOAT ANCHOR??? - by GarySP - 07-10-2022, 07:33 PM
RE: I NOW OWN A BOAT ANCHOR??? - by GarySP - 07-11-2022, 09:46 AM
RE: I NOW OWN A BOAT ANCHOR??? - by EdHolland - 08-09-2022, 11:15 PM
RE: I NOW OWN A BOAT ANCHOR??? - by GarySP - 08-10-2022, 08:38 AM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 8820 online users. [Complete List]
» 3 Member(s) | 8817 Guest(s)
