Atwater Kent 82, restoration.
#48
I'm with you on that, there may be some order to follow. Otherwise you may get worse results. I'm just looking at the docs for the AK L1. It may have been the last AK TRF, 1930. Looks like the PT is shot. Can't even get out of the gate with this one.
Atwater Kent 82, restoration. - by morzh - 05-22-2022, 06:10 PM
RE: Atwater Kent 82, restoration. - by Jayce - 05-22-2022, 07:29 PM
RE: Atwater Kent 82, restoration. - by morzh - 05-22-2022, 08:45 PM
RE: Atwater Kent 82, restoration. - by Jayce - 05-22-2022, 10:12 PM
RE: Atwater Kent 82, restoration. - by morzh - 05-22-2022, 10:56 PM
RE: Atwater Kent 82, restoration. - by Jayce - 05-23-2022, 11:19 AM
RE: Atwater Kent 82, restoration. - by morzh - 05-23-2022, 09:30 PM
RE: Atwater Kent 82, restoration. - by Eliot Ness - 05-24-2022, 10:04 AM
RE: Atwater Kent 82, restoration. - by Chas - 05-24-2022, 10:22 AM
RE: Atwater Kent 82, restoration. - by morzh - 05-24-2022, 11:51 AM
RE: Atwater Kent 82, restoration. - by Arran - 05-25-2022, 02:27 AM
RE: Atwater Kent 82, restoration. - by morzh - 05-25-2022, 09:57 PM
RE: Atwater Kent 82, restoration. - by morzh - 05-28-2022, 09:15 PM
RE: Atwater Kent 82, restoration. - by RodB - 05-28-2022, 10:41 PM
RE: Atwater Kent 82, restoration. - by radiorich - 05-28-2022, 10:53 PM
RE: Atwater Kent 82, restoration. - by morzh - 05-29-2022, 12:09 PM
RE: Atwater Kent 82, restoration. - by radiorich - 05-29-2022, 12:56 PM
RE: Atwater Kent 82, restoration. - by morzh - 05-29-2022, 03:37 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-04-2022, 08:49 PM
RE: Atwater Kent 82, restoration. - by radiorich - 06-05-2022, 12:13 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-05-2022, 12:24 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-05-2022, 01:16 PM
RE: Atwater Kent 82, restoration. - by Eliot Ness - 06-05-2022, 01:43 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-05-2022, 03:17 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-05-2022, 08:58 PM
RE: Atwater Kent 82, restoration. - by radiorich - 06-06-2022, 01:25 AM
RE: Atwater Kent 82, restoration. - by morzh - 06-06-2022, 10:06 AM
RE: Atwater Kent 82, restoration. - by radiorich - 06-06-2022, 08:25 PM
RE: Atwater Kent 82, restoration. - by radiorich - 06-06-2022, 08:26 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-06-2022, 10:42 PM
RE: Atwater Kent 82, restoration. - by radiorich - 06-06-2022, 11:37 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-06-2022, 11:46 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-09-2022, 12:29 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-09-2022, 01:32 PM
RE: Atwater Kent 82, restoration. - by rfeenstra - 06-09-2022, 06:54 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-12-2022, 10:50 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-14-2022, 10:44 PM
RE: Atwater Kent 82, restoration. - by radiorich - 06-14-2022, 11:45 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-18-2022, 10:35 PM
RE: Atwater Kent 82, restoration. - by morzh - 06-19-2022, 06:19 PM
RE: Atwater Kent 82, restoration. - by morzh - 07-02-2022, 07:06 PM
RE: Atwater Kent 82, restoration. - by morzh - 07-04-2022, 12:18 PM
RE: Atwater Kent 82, restoration. - by morzh - 07-04-2022, 02:40 PM
RE: Atwater Kent 82, restoration. - by morzh - 07-09-2022, 02:31 PM
RE: Atwater Kent 82, restoration. - by RodB - 07-09-2022, 03:27 PM
RE: Atwater Kent 82, restoration. - by morzh - 07-09-2022, 05:29 PM
RE: Atwater Kent 82, restoration. - by RodB - 07-09-2022, 06:34 PM
RE: Atwater Kent 82, restoration. - by morzh - 07-10-2022, 01:34 PM
RE: Atwater Kent 82, restoration. - by morzh - 07-11-2022, 09:13 PM
RE: Atwater Kent 82, restoration. - by morzh - 07-12-2022, 10:55 PM
RE: Atwater Kent 82, restoration. - by RodB - 07-13-2022, 10:24 AM
RE: Atwater Kent 82, restoration. - by morzh - 07-13-2022, 11:03 AM
RE: Atwater Kent 82, restoration. - by RodB - 07-13-2022, 12:44 PM
RE: Atwater Kent 82, restoration. - by morzh - 07-13-2022, 03:47 PM
RE: Atwater Kent 82, restoration. - by morzh - 07-13-2022, 09:02 PM
RE: Atwater Kent 82, restoration. - by GarySP - 07-13-2022, 09:30 PM
RE: Atwater Kent 82, restoration. - by morzh - 07-13-2022, 09:42 PM
RE: Atwater Kent 82, restoration. - by tbone - 07-14-2022, 07:08 AM
RE: Atwater Kent 82, restoration. - by PhilcoJohn - 07-14-2022, 07:42 AM
RE: Atwater Kent 82, restoration. - by RodB - 07-14-2022, 08:33 AM
RE: Atwater Kent 82, restoration. - by Eliot Ness - 07-14-2022, 06:27 PM
RE: Atwater Kent 82, restoration. - by GarySP - 07-15-2022, 09:08 AM
RE: Atwater Kent 82, restoration. - by morzh - 07-15-2022, 11:48 PM
RE: Atwater Kent 82, restoration. - by MrFixr55 - 07-16-2022, 11:23 AM
RE: Atwater Kent 82, restoration. - by morzh - 07-16-2022, 12:45 PM
