decals
A friend is refinishing a cabinet for the 48-482 Philco radio. We purchased the decals from Radio Daze. How can the decals be protected with a finish to protect from wear from constant rubbing of the fingers around the controls? What type of protectant should be used over the decals?
decals - by radiotechman - 05-16-2011, 03:04 PM
Re: decals - by exray - 05-16-2011, 08:06 PM
Re: decals - by Marsupial - 05-16-2011, 10:21 PM
Re: decals - by exray - 05-17-2011, 10:13 AM
Re: decals - by dcastor - 08-10-2011, 01:41 PM
Re: decals - by exray - 08-11-2011, 12:53 PM
Re: decals - by Ron Ramirez - 08-11-2011, 09:32 PM
Re: decals - by Marsupial - 08-12-2011, 01:19 AM
Re: decals - by Ron Ramirez - 08-12-2011, 06:32 AM
Re: decals - by Marsupial - 08-12-2011, 12:59 PM
There are currently 9959 online users. [Complete List]
» 2 Member(s) | 9957 Guest(s)
