BCB Antenna Ideas
Quote:My questions are- what is the length of twisted pair lead in before noticeable degradation of performance? What should the twist per inch be for best performance? Any length of transmission line has loss...
For a twisted pair, #18 MTW, twist 1 turn in 2" should yield roughly 72ohms balanced. Warm the cable with a heat gun to "set" the insulation to reduce unraveling. Will want to use on a radio with a balanced input if practical.
Pliny the younger
BCB Antenna Ideas - by RGK20m3 - 07-22-2022, 03:49 PM
RE: BCB Antenna Ideas - by poulsbobill - 07-22-2022, 04:46 PM
RE: BCB Antenna Ideas - by Chas - 07-22-2022, 11:02 PM
RE: BCB Antenna Ideas - by RGK20m3 - 07-24-2022, 07:15 PM
RE: BCB Antenna Ideas - by Ron Ramirez - 07-25-2022, 12:11 PM
RE: BCB Antenna Ideas - by Chas - 07-25-2022, 01:12 PM
RE: BCB Antenna Ideas - by Ron Ramirez - 07-25-2022, 01:45 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 07-26-2022, 09:56 AM
RE: BCB Antenna Ideas - by Simon Wa3uay - 07-28-2022, 04:41 PM
RE: BCB Antenna Ideas - by mikethedruid - 07-28-2022, 07:33 PM
RE: BCB Antenna Ideas - by Chas - 07-28-2022, 08:30 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 07-29-2022, 10:29 AM
RE: BCB Antenna Ideas - by radio1 - 07-30-2022, 07:38 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-01-2022, 12:41 PM
RE: BCB Antenna Ideas - by Chas - 08-01-2022, 01:18 PM
RE: BCB Antenna Ideas - by RodB - 08-01-2022, 05:05 PM
RE: BCB Antenna Ideas - by Chas - 08-01-2022, 05:40 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-02-2022, 08:28 AM
RE: BCB Antenna Ideas - by mikethedruid - 08-02-2022, 10:42 AM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-02-2022, 10:58 AM
RE: BCB Antenna Ideas - by mikethedruid - 08-02-2022, 12:44 PM
RE: BCB Antenna Ideas - by GarySP - 08-02-2022, 02:10 PM
RE: BCB Antenna Ideas - by RGK20m3 - 08-02-2022, 06:23 PM
RE: BCB Antenna Ideas - by RGK20m3 - 08-02-2022, 06:28 PM
RE: BCB Antenna Ideas - by Chas - 08-03-2022, 09:44 AM
RE: BCB Antenna Ideas - by RGK20m3 - 08-03-2022, 10:14 AM
RE: BCB Antenna Ideas - by Chas - 08-03-2022, 10:57 AM
RE: BCB Antenna Ideas - by mikethedruid - 08-03-2022, 12:44 PM
RE: BCB Antenna Ideas - by RGK20m3 - 08-03-2022, 02:25 PM
RE: BCB Antenna Ideas - by RGK20m3 - 08-04-2022, 05:18 PM
RE: BCB Antenna Ideas - by Chas - 08-04-2022, 05:45 PM
RE: BCB Antenna Ideas - by mikethedruid - 08-04-2022, 07:08 PM
RE: BCB Antenna Ideas - by RGK20m3 - 08-05-2022, 07:21 AM
RE: BCB Antenna Ideas - by vinzer - 08-05-2022, 12:24 PM
RE: BCB Antenna Ideas - by Ron Ramirez - 08-05-2022, 04:13 PM
RE: BCB Antenna Ideas - by RGK20m3 - 08-05-2022, 04:47 PM
RE: BCB Antenna Ideas - by mikethedruid - 08-05-2022, 05:11 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-05-2022, 08:17 PM
RE: BCB Antenna Ideas - by David - 08-05-2022, 08:46 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-06-2022, 02:19 PM
RE: BCB Antenna Ideas - by RGK20m3 - 08-06-2022, 03:22 PM
RE: BCB Antenna Ideas - by radio1 - 08-07-2022, 06:08 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-08-2022, 08:50 AM
RE: BCB Antenna Ideas - by Ron Ramirez - 08-08-2022, 08:57 AM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-08-2022, 09:03 AM
RE: BCB Antenna Ideas - by Chas - 08-08-2022, 10:06 AM
RE: BCB Antenna Ideas - by GarySP - 08-08-2022, 11:29 AM
RE: BCB Antenna Ideas - by poulsbobill - 08-08-2022, 11:37 AM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-08-2022, 12:44 PM
RE: BCB Antenna Ideas - by Chas - 08-08-2022, 01:27 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-19-2022, 01:24 PM
RE: BCB Antenna Ideas - by David - 08-19-2022, 01:59 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 09-04-2022, 02:44 PM
RE: BCB Antenna Ideas - by thirtiesradio - 09-05-2022, 04:13 AM
RE: BCB Antenna Ideas - by Ron Ramirez - 09-05-2022, 12:10 PM
RE: BCB Antenna Ideas - by Ron Ramirez - 09-05-2022, 12:11 PM
RE: BCB Antenna Ideas - by thirtiesradio - 09-05-2022, 02:23 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 09-05-2022, 04:25 PM
RE: BCB Antenna Ideas - by GarySP - 09-05-2022, 08:35 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 09-06-2022, 12:40 PM
Hi Richard. Yes, we are waiting for warm weather. I have more than a dozen hulls waiting to be painted.RadioSvit — 11:06 AM
Then it is even easier. Yep, my GE guide also says "Silicon".morzh — 09:43 AM
Mike, according to my ECG replacement guide, the AR107 & AR108 both cross reference to a ECG 123A as does a GE-10. T...462ron — 09:41 AM
The 66 Ohm filter in the 1st detector's plate circuit. Look in the early version sch. Here it is, the spiral that ma...morzh — 09:11 AM
Ron yes, that was found. The problem is trying to find GE-10 for AR107/108. I could not find even mentioning of it. ...morzh — 09:06 AM
Your output transistor X6 cross references to a GE-3 transistor and I’ve used that before. There are a few here on eBay…...462ron — 07:58 AM
Mike; Where was this RF choke located? I remember seeing on a few sets that had detector-amplifiers ahead of the powe...Arran — 02:29 AM
Thank you very much. I'll let you know how it goes.R3Sons — 11:00 PM
Hello mike, Nice job hopefully it works and I am sure it will. Sincerely Richardradiorich — 09:15 PM
Hello Peter, I am glad you got the radios and I too have that same zenith in my collection ! I am also waiting for the...radiorich — 08:52 PM
There are currently 3306 online users. [Complete List]
» 1 Member(s) | 3305 Guest(s)
