BCB Antenna Ideas
Your radio. being in a condo, results in everyone's wall warts, pc/laptop power supplies (especially cheap ones), routers, wifi's and other devices ultimately destroying your reception. Interference is broadcast back through the condo wiring. Even if you disconnect all of your pc devices etc., others devices in the condo will destroy reception. Use a battery powered am radio to walk around your condo unit to hear the interference (same interference) and where it is less, you might find a better location for the radio. Then you can attack a better antenna solution for the radio.
BCB Antenna Ideas - by RGK20m3 - 07-22-2022, 03:49 PM
RE: BCB Antenna Ideas - by poulsbobill - 07-22-2022, 04:46 PM
RE: BCB Antenna Ideas - by Chas - 07-22-2022, 11:02 PM
RE: BCB Antenna Ideas - by RGK20m3 - 07-24-2022, 07:15 PM
RE: BCB Antenna Ideas - by Ron Ramirez - 07-25-2022, 12:11 PM
RE: BCB Antenna Ideas - by Chas - 07-25-2022, 01:12 PM
RE: BCB Antenna Ideas - by Ron Ramirez - 07-25-2022, 01:45 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 07-26-2022, 09:56 AM
RE: BCB Antenna Ideas - by Simon Wa3uay - 07-28-2022, 04:41 PM
RE: BCB Antenna Ideas - by mikethedruid - 07-28-2022, 07:33 PM
RE: BCB Antenna Ideas - by Chas - 07-28-2022, 08:30 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 07-29-2022, 10:29 AM
RE: BCB Antenna Ideas - by radio1 - 07-30-2022, 07:38 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-01-2022, 12:41 PM
RE: BCB Antenna Ideas - by Chas - 08-01-2022, 01:18 PM
RE: BCB Antenna Ideas - by RodB - 08-01-2022, 05:05 PM
RE: BCB Antenna Ideas - by Chas - 08-01-2022, 05:40 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-02-2022, 08:28 AM
RE: BCB Antenna Ideas - by mikethedruid - 08-02-2022, 10:42 AM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-02-2022, 10:58 AM
RE: BCB Antenna Ideas - by mikethedruid - 08-02-2022, 12:44 PM
RE: BCB Antenna Ideas - by GarySP - 08-02-2022, 02:10 PM
RE: BCB Antenna Ideas - by RGK20m3 - 08-02-2022, 06:23 PM
RE: BCB Antenna Ideas - by RGK20m3 - 08-02-2022, 06:28 PM
RE: BCB Antenna Ideas - by Chas - 08-03-2022, 09:44 AM
RE: BCB Antenna Ideas - by RGK20m3 - 08-03-2022, 10:14 AM
RE: BCB Antenna Ideas - by Chas - 08-03-2022, 10:57 AM
RE: BCB Antenna Ideas - by mikethedruid - 08-03-2022, 12:44 PM
RE: BCB Antenna Ideas - by RGK20m3 - 08-03-2022, 02:25 PM
RE: BCB Antenna Ideas - by RGK20m3 - 08-04-2022, 05:18 PM
RE: BCB Antenna Ideas - by Chas - 08-04-2022, 05:45 PM
RE: BCB Antenna Ideas - by mikethedruid - 08-04-2022, 07:08 PM
RE: BCB Antenna Ideas - by RGK20m3 - 08-05-2022, 07:21 AM
RE: BCB Antenna Ideas - by vinzer - 08-05-2022, 12:24 PM
RE: BCB Antenna Ideas - by Ron Ramirez - 08-05-2022, 04:13 PM
RE: BCB Antenna Ideas - by RGK20m3 - 08-05-2022, 04:47 PM
RE: BCB Antenna Ideas - by mikethedruid - 08-05-2022, 05:11 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-05-2022, 08:17 PM
RE: BCB Antenna Ideas - by David - 08-05-2022, 08:46 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-06-2022, 02:19 PM
RE: BCB Antenna Ideas - by RGK20m3 - 08-06-2022, 03:22 PM
RE: BCB Antenna Ideas - by radio1 - 08-07-2022, 06:08 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-08-2022, 08:50 AM
RE: BCB Antenna Ideas - by Ron Ramirez - 08-08-2022, 08:57 AM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-08-2022, 09:03 AM
RE: BCB Antenna Ideas - by Chas - 08-08-2022, 10:06 AM
RE: BCB Antenna Ideas - by GarySP - 08-08-2022, 11:29 AM
RE: BCB Antenna Ideas - by poulsbobill - 08-08-2022, 11:37 AM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-08-2022, 12:44 PM
RE: BCB Antenna Ideas - by Chas - 08-08-2022, 01:27 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-19-2022, 01:24 PM
RE: BCB Antenna Ideas - by David - 08-19-2022, 01:59 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 09-04-2022, 02:44 PM
RE: BCB Antenna Ideas - by thirtiesradio - 09-05-2022, 04:13 AM
RE: BCB Antenna Ideas - by Ron Ramirez - 09-05-2022, 12:10 PM
RE: BCB Antenna Ideas - by Ron Ramirez - 09-05-2022, 12:11 PM
RE: BCB Antenna Ideas - by thirtiesradio - 09-05-2022, 02:23 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 09-05-2022, 04:25 PM
RE: BCB Antenna Ideas - by GarySP - 09-05-2022, 08:35 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 09-06-2022, 12:40 PM
Users browsing this thread: 33 Guest(s)
Hi Richard. Yes, we are waiting for warm weather. I have more than a dozen hulls waiting to be painted.RadioSvit — 11:06 AM
Then it is even easier. Yep, my GE guide also says "Silicon".morzh — 09:43 AM
Mike, according to my ECG replacement guide, the AR107 & AR108 both cross reference to a ECG 123A as does a GE-10. T...462ron — 09:41 AM
The 66 Ohm filter in the 1st detector's plate circuit. Look in the early version sch. Here it is, the spiral that ma...morzh — 09:11 AM
Ron yes, that was found. The problem is trying to find GE-10 for AR107/108. I could not find even mentioning of it. ...morzh — 09:06 AM
Your output transistor X6 cross references to a GE-3 transistor and I’ve used that before. There are a few here on eBay…...462ron — 07:58 AM
Mike; Where was this RF choke located? I remember seeing on a few sets that had detector-amplifiers ahead of the powe...Arran — 02:29 AM
Thank you very much. I'll let you know how it goes.R3Sons — 11:00 PM
Hello mike, Nice job hopefully it works and I am sure it will. Sincerely Richardradiorich — 09:15 PM
Hello Peter, I am glad you got the radios and I too have that same zenith in my collection ! I am also waiting for the...radiorich — 08:52 PM
There are currently 3371 online users. [Complete List]
» 1 Member(s) | 3370 Guest(s)
