Threads: 8
City: S. Dartmouth
State, Province, Country: MA
Quote:especially the 'transformer' with ground wire going to a 'standpipe'
Coax was not in wide use at the time of the creation of this antenna kit. So twisted pair was the receiving transmission line of the day. If the wire size and insulation thickness is like what was common power cord of the era, the nominal impedance would be 72 ohms. This is an ideal match for a dipole, however, such a dipole is good only at resonance and not so good off resonance. Off resonance the feed-point impedance rises. Twisted pair is tolerable to this off resonance much more than coax. The twisted nature cancels external noises and metal objects in near proximity but should not be against such conductors like metal siding or stucco lath.
The antenna input device should be very interesting to see how broadband matching is used or even if matching need be accomplished, may be no more than a lightning protection device and a terminus for conductors to enter the building.
RCA also provided antenna kits, just as hard to find in new condition.
Thanks for providing the antenna data...
Chas
Pliny the younger
RE: BCB Antenna Ideas - by Chas - 08-01-2022, 01:18 PM
Users browsing this thread: 38 Guest(s)
Hi Richard. Yes, we are waiting for warm weather. I have more than a dozen hulls waiting to be painted.RadioSvit — 11:06 AM |
Then it is even easier.
Yep, my GE guide also says "Silicon".morzh — 09:43 AM |
Mike, according to my ECG replacement guide, the AR107 & AR108 both cross reference to a ECG 123A as does a GE-10. T...462ron — 09:41 AM |
The 66 Ohm filter in the 1st detector's plate circuit.
Look in the early version sch.
Here it is, the spiral that ma...morzh — 09:11 AM |
Ron
yes, that was found. The problem is trying to find GE-10 for AR107/108.
I could not find even mentioning of it.
...morzh — 09:06 AM |
Your output transistor X6 cross references to a GE-3 transistor and I’ve used that before. There are a few here on eBay…...462ron — 07:58 AM |
Mike;
Where was this RF choke located? I remember seeing on a few sets that had detector-amplifiers ahead of the powe...Arran — 02:29 AM |
Thank you very much. I'll let you know how it goes.R3Sons — 11:00 PM |
Hello mike,
Nice job hopefully it works and I am sure it will.
Sincerely Richardradiorich — 09:15 PM |
Hello Peter,
I am glad you got the radios and I too have that same zenith in my collection !
I am also waiting for the...radiorich — 08:52 PM |
There are currently 3481 online users. [Complete List] » 2 Member(s) | 3479 Guest(s)
