decals
I usually apply mine after the first clear coat. Just soak in water for about 30 seconds and slide it off the paper directly onto the surface. A couple drops of water will help in sliding it into the exact position. Then just tamp it dry and carefully smooth it out with a paper towel or soft cloth. If it gets wrinkled or a corner gets bent under just use a couple drops of water to rework it.
I let them dry for a good long time, often overnight, before spraying the next lacquer coat. It needs to be bone dry so that any trapped moisture doesn't show up as a blush spot in the lacquer.
decals - by radiotechman - 05-16-2011, 03:04 PM
Re: decals - by exray - 05-16-2011, 08:06 PM
Re: decals - by Marsupial - 05-16-2011, 10:21 PM
Re: decals - by exray - 05-17-2011, 10:13 AM
Re: decals - by dcastor - 08-10-2011, 01:41 PM
Re: decals - by exray - 08-11-2011, 12:53 PM
Re: decals - by Ron Ramirez - 08-11-2011, 09:32 PM
Re: decals - by Marsupial - 08-12-2011, 01:19 AM
Re: decals - by Ron Ramirez - 08-12-2011, 06:32 AM
Re: decals - by Marsupial - 08-12-2011, 12:59 PM
There are currently 10533 online users. [Complete List]
» 3 Member(s) | 10530 Guest(s)
