BCB Antenna Ideas
#33
On my 38-690, the link between the black and ground terminals is a soldered wire inside the chassis; I believe this to be factory, as it is a continuous cloth covered wire from the 2 lugs to the RF sub chassis tab. From the tab there is an identical wire bonding the RF sub chassis to the main chassis.
Of course, it could have been changed at any point in the last 85 years. I do see how the antenna coil could provide a balanced input, but seems would create an issue as there is no ground reference on the circuit. Most I have seen have the coil center tapped.
Per my above post, at least one of the Philco dipole kits has a “transformer” at the mid point, and the literature for that kit (Philco Library), instructs an additional ground to this transformer if there are interference issues. The photo link that I posted shows what appears to be a balun/ transformer included in the kit. Perhaps actually an balanced to balanced matching transformer?
Not trying to argue, just trying to understand. Incidentally, that schematic you provided does not match the 38-690 schematic.
BCB Antenna Ideas - by RGK20m3 - 07-22-2022, 03:49 PM
RE: BCB Antenna Ideas - by poulsbobill - 07-22-2022, 04:46 PM
RE: BCB Antenna Ideas - by Chas - 07-22-2022, 11:02 PM
RE: BCB Antenna Ideas - by RGK20m3 - 07-24-2022, 07:15 PM
RE: BCB Antenna Ideas - by Ron Ramirez - 07-25-2022, 12:11 PM
RE: BCB Antenna Ideas - by Chas - 07-25-2022, 01:12 PM
RE: BCB Antenna Ideas - by Ron Ramirez - 07-25-2022, 01:45 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 07-26-2022, 09:56 AM
RE: BCB Antenna Ideas - by Simon Wa3uay - 07-28-2022, 04:41 PM
RE: BCB Antenna Ideas - by mikethedruid - 07-28-2022, 07:33 PM
RE: BCB Antenna Ideas - by Chas - 07-28-2022, 08:30 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 07-29-2022, 10:29 AM
RE: BCB Antenna Ideas - by radio1 - 07-30-2022, 07:38 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-01-2022, 12:41 PM
RE: BCB Antenna Ideas - by Chas - 08-01-2022, 01:18 PM
RE: BCB Antenna Ideas - by RodB - 08-01-2022, 05:05 PM
RE: BCB Antenna Ideas - by Chas - 08-01-2022, 05:40 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-02-2022, 08:28 AM
RE: BCB Antenna Ideas - by mikethedruid - 08-02-2022, 10:42 AM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-02-2022, 10:58 AM
RE: BCB Antenna Ideas - by mikethedruid - 08-02-2022, 12:44 PM
RE: BCB Antenna Ideas - by GarySP - 08-02-2022, 02:10 PM
RE: BCB Antenna Ideas - by RGK20m3 - 08-02-2022, 06:23 PM
RE: BCB Antenna Ideas - by RGK20m3 - 08-02-2022, 06:28 PM
RE: BCB Antenna Ideas - by Chas - 08-03-2022, 09:44 AM
RE: BCB Antenna Ideas - by RGK20m3 - 08-03-2022, 10:14 AM
RE: BCB Antenna Ideas - by Chas - 08-03-2022, 10:57 AM
RE: BCB Antenna Ideas - by mikethedruid - 08-03-2022, 12:44 PM
RE: BCB Antenna Ideas - by RGK20m3 - 08-03-2022, 02:25 PM
RE: BCB Antenna Ideas - by RGK20m3 - 08-04-2022, 05:18 PM
RE: BCB Antenna Ideas - by Chas - 08-04-2022, 05:45 PM
RE: BCB Antenna Ideas - by mikethedruid - 08-04-2022, 07:08 PM
RE: BCB Antenna Ideas - by RGK20m3 - 08-05-2022, 07:21 AM
RE: BCB Antenna Ideas - by vinzer - 08-05-2022, 12:24 PM
RE: BCB Antenna Ideas - by Ron Ramirez - 08-05-2022, 04:13 PM
RE: BCB Antenna Ideas - by RGK20m3 - 08-05-2022, 04:47 PM
RE: BCB Antenna Ideas - by mikethedruid - 08-05-2022, 05:11 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-05-2022, 08:17 PM
RE: BCB Antenna Ideas - by David - 08-05-2022, 08:46 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-06-2022, 02:19 PM
RE: BCB Antenna Ideas - by RGK20m3 - 08-06-2022, 03:22 PM
RE: BCB Antenna Ideas - by radio1 - 08-07-2022, 06:08 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-08-2022, 08:50 AM
RE: BCB Antenna Ideas - by Ron Ramirez - 08-08-2022, 08:57 AM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-08-2022, 09:03 AM
RE: BCB Antenna Ideas - by Chas - 08-08-2022, 10:06 AM
RE: BCB Antenna Ideas - by GarySP - 08-08-2022, 11:29 AM
RE: BCB Antenna Ideas - by poulsbobill - 08-08-2022, 11:37 AM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-08-2022, 12:44 PM
RE: BCB Antenna Ideas - by Chas - 08-08-2022, 01:27 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 08-19-2022, 01:24 PM
RE: BCB Antenna Ideas - by David - 08-19-2022, 01:59 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 09-04-2022, 02:44 PM
RE: BCB Antenna Ideas - by thirtiesradio - 09-05-2022, 04:13 AM
RE: BCB Antenna Ideas - by Ron Ramirez - 09-05-2022, 12:10 PM
RE: BCB Antenna Ideas - by Ron Ramirez - 09-05-2022, 12:11 PM
RE: BCB Antenna Ideas - by thirtiesradio - 09-05-2022, 02:23 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 09-05-2022, 04:25 PM
RE: BCB Antenna Ideas - by GarySP - 09-05-2022, 08:35 PM
RE: BCB Antenna Ideas - by Simon Wa3uay - 09-06-2022, 12:40 PM
Users browsing this thread: 34 Guest(s)
Hi Richard. Yes, we are waiting for warm weather. I have more than a dozen hulls waiting to be painted.RadioSvit — 11:06 AM
Then it is even easier. Yep, my GE guide also says "Silicon".morzh — 09:43 AM
Mike, according to my ECG replacement guide, the AR107 & AR108 both cross reference to a ECG 123A as does a GE-10. T...462ron — 09:41 AM
The 66 Ohm filter in the 1st detector's plate circuit. Look in the early version sch. Here it is, the spiral that ma...morzh — 09:11 AM
Ron yes, that was found. The problem is trying to find GE-10 for AR107/108. I could not find even mentioning of it. ...morzh — 09:06 AM
Your output transistor X6 cross references to a GE-3 transistor and I’ve used that before. There are a few here on eBay…...462ron — 07:58 AM
Mike; Where was this RF choke located? I remember seeing on a few sets that had detector-amplifiers ahead of the powe...Arran — 02:29 AM
Thank you very much. I'll let you know how it goes.R3Sons — 11:00 PM
Hello mike, Nice job hopefully it works and I am sure it will. Sincerely Richardradiorich — 09:15 PM
Hello Peter, I am glad you got the radios and I too have that same zenith in my collection ! I am also waiting for the...radiorich — 08:52 PM
There are currently 3455 online users. [Complete List]
» 1 Member(s) | 3454 Guest(s)
