Model 118 frozen Bandswitch Help
He, he, I often forget that much of the tools I use are truly vintage, many much older than I. The Weller I have is very large, very heavy with a medium brown Bakelite case. Model number plate is missing. I run that gun to the point its smokin' and it keeps on keepin' on. Uses the large copper tips, I often makeup tips of #12 or #10 buss wire as the OEM tips are getting pricey. That is the gun I use on frozen switches and tuning shafts.
Henry I do agree with
Yes, I have a torch, a very small Weller (again) mini-butane torch/soldering iron. I seldom use it because or fire hazard but it's great for jobs away from power, like antenna building.
Do be careful backing up the switch body as it can twist, distort the indent plate, break the wafers or permanently loosen the mounting bushing from the frontplate of the switch.
Henry, I do agree with John, it ain't hot enough yet...
Chas
Pliny the younger
Model 118 frozen Bandswitch Help - by radiohenry - 08-03-2022, 02:51 PM
RE: Model 118 frozen Bandswitch Help - by morzh - 08-03-2022, 10:38 PM
RE: Model 118 frozen Bandswitch Help - by David - 08-04-2022, 02:00 PM
RE: Model 118 frozen Bandswitch Help - by Chas - 08-04-2022, 06:00 PM
RE: Model 118 frozen Bandswitch Help - by morzh - 08-04-2022, 06:40 PM
RE: Model 118 frozen Bandswitch Help - by Chas - 08-04-2022, 09:55 PM
RE: Model 118 frozen Bandswitch Help - by morzh - 08-04-2022, 10:49 PM
RE: Model 118 frozen Bandswitch Help - by morzh - 08-05-2022, 10:24 PM
RE: Model 118 frozen Bandswitch Help - by Chas - 08-06-2022, 11:12 AM
RE: Model 118 frozen Bandswitch Help - by GarySP - 08-07-2022, 02:22 PM
RE: Model 118 frozen Bandswitch Help - by GarySP - 08-08-2022, 11:37 AM
RE: Model 118 frozen Bandswitch Help - by Greg - 08-10-2022, 02:54 PM
RE: Model 118 frozen Bandswitch Help - by morzh - 08-13-2022, 10:17 PM
RE: Model 118 frozen Bandswitch Help - by GarySP - 08-14-2022, 08:17 AM
RE: Model 118 frozen Bandswitch Help - by morzh - 08-14-2022, 07:31 PM
RE: Model 118 frozen Bandswitch Help - by Chas - 08-17-2022, 03:40 PM
Users browsing this thread: 14 Guest(s)
I did run into a guy on the FB Philco Radio Enthusiast page who is searching for the output transformer for a 46-480, so...jrblasde — 10:12 PM
I may have just found the IF transformer. There is a person on FB Marketplace who is selling a 46-480 in need of some re...jrblasde — 10:10 PM
Restoring Philco 96
Have just bought this. The field coil tested at 3.18K. The cone has one small tear. I think this is what I need. Not ...morzh — 06:22 PM
91H Code 126 Restore
Well I am making progress with my first Philco.  It took a bit to figure out the on/off/band switch and tone control nei...RealRider — 01:33 PM
Interesting design in that the plate circuits of the first detector and IF stage take full B+ right from the filament of...462ron — 08:44 AM
Hello mike, that is lucky that you were able to do that ! I have one of my radios that the volume control is getting s...radiorich — 12:18 AM
That one cannot be taken apart well. It is riveted. But the domed switch luckily has some spacing (not much and not inte...morzh — 09:44 PM
Hello Mike, that D5 is great for switches and I do the same I will try spraying it through a side hole first before tak...radiorich — 09:38 PM
Almost decided ot turn it on, but didn't like the power switch being 50 - 100 Ohms, so it is the same exact switch as in...morzh — 08:56 PM
Philco 49-1040
+1 Bob. Yeah, they bought it in 1949 or so, but by 1960, with the CRT starting to dim and after having the set repaired...MrFixr55 — 04:41 PM
There are currently 3699 online users. [Complete List]
» 1 Member(s) | 3698 Guest(s)
