Philco 65 paper capacitors
If memory serves me correctly the resistor is wire wound around the cardboard form of the capacitor. Typically wire wound resistors don't change value like carbon resistors. They are very stable under load even overload. I would suspect that it came from the factory that way.
When I've serviced some of these early sets I've just clipped the ground wire off of the cap. And soldered a new one in it's place (cap). The resistor is used to decouple rf signal from getting into the hv supply. The value isn't all that critical. Same with the cap it's job is to couple any rf signal to ground but not short the hv to ground...
If it oscillates when you get done or you can't sleep at night go ahead and add 100 ohms @ 1/2w in series.
Lot of working room eh.
Philco 65 paper capacitors - by Kestas - 08-06-2022, 10:38 PM
RE: Philco 65 paper capacitors - by Radioroslyn - 08-07-2022, 12:01 PM
RE: Philco 65 paper capacitors - by morzh - 08-07-2022, 03:47 PM
RE: Philco 65 paper capacitors - by Radioroslyn - 08-07-2022, 04:33 PM
RE: Philco 65 paper capacitors - by Kestas - 08-07-2022, 04:36 PM
RE: Philco 65 paper capacitors - by Ron Ramirez - 08-07-2022, 06:35 PM
RE: Philco 65 paper capacitors - by morzh - 08-07-2022, 06:55 PM
RE: Philco 65 paper capacitors - by Ron Ramirez - 08-07-2022, 08:12 PM
RE: Philco 65 paper capacitors - by Kestas - 08-08-2022, 08:25 PM
RE: Philco 65 paper capacitors - by Ron Ramirez - 08-08-2022, 08:38 PM
Gloritone 27 Radio
Hello, I sure hope there is someone out there that knows this radio. I am just getting started on scoping out the schema...dconant — 03:36 PM
Philco 49-1040
Really cool old TV Mr. Anderson! Just being complete, clean and unmolested means a lot! I love how the tuner is flipped ...TV MAN — 10:36 AM
I did run into a guy on the FB Philco Radio Enthusiast page who is searching for the output transformer for a 46-480, so...jrblasde — 10:12 PM
I may have just found the IF transformer. There is a person on FB Marketplace who is selling a 46-480 in need of some re...jrblasde — 10:10 PM
Restoring Philco 96
Have just bought this. The field coil tested at 3.18K. The cone has one small tear. I think this is what I need. Not ...morzh — 06:22 PM
91H Code 126 Restore
Well I am making progress with my first Philco.  It took a bit to figure out the on/off/band switch and tone control nei...RealRider — 01:33 PM
Interesting design in that the plate circuits of the first detector and IF stage take full B+ right from the filament of...462ron — 08:44 AM
Hello mike, that is lucky that you were able to do that ! I have one of my radios that the volume control is getting s...radiorich — 12:18 AM
That one cannot be taken apart well. It is riveted. But the domed switch luckily has some spacing (not much and not inte...morzh — 09:44 PM
Hello Mike, that D5 is great for switches and I do the same I will try spraying it through a side hole first before tak...radiorich — 09:38 PM
