Philco 65 paper capacitors
> What's the best way to gut the capacitor? I'd rather do it with the resistor intact if possible.
That likely isn't happening.
The best way to remove the guts is with heat. First, try to unsolder the tiny leads of the capacitor (and resistor if applicable) from the solder terminals.
Now, if you have an old toaster oven that you no longer use for food, this would be the best choice. Bake them for about 30 minutes at 225 to 250 degrees Fahrenheit. If you do not have one of these, the capacitors will need to be heated in some way until you can remove the innards. The components are sealed inside with a black waxy substance, just like Philco bakelite blocks were sealed. Grab the end of the capacitor which mounts to the chassis with a pair of needle nose pliers while the unit is hot, and push the stuffing out with an old screwdriver.
Here's how I rebuilt my Philco 65, from my blog.
Philco model 65 Repairs - Part 1
Philco model 65 Repairs - Part 2
Philco model 65 Repairs - Part 3
Philco model 65 Repairs - Part 4
Philco model 65 Repairs - Part 5
Philco model 65 Repairs - Part 6
Philco model 65 Repairs - Part 7 (Epilog)
Part 4 details how I rebuilt the capacitors in my set.
You mentioned some of the capacitors in your set having resistors of 100 ohms, not 200 ohms. This is interesting, as the original Philco data specified 200 ohm resistors in those capacitors. I suspect this may be another case of Philco making a running change and not documenting it.
Please do me (and all of us) a favor. Please specify exactly which capacitor/resistor assemblies measure 100 ohms instead of 200 ohms, Use the Philco part numbers as shown on the schematic; i.e. whether it is (5), (6), (9), (10), and/or (27). My 65 set oscillates if I turn the volume control up too high; I'm now wondering if I need to change some of my 200 ohm resistors to 100 ohm? I would need to study the schematic further.
Oh, and 1/2 watt resistors are suitable for replacements for these resistors. You can use 1 watt if you wish. They don't have to be wirewound.
Philco 65 paper capacitors - by Kestas - 08-06-2022, 10:38 PM
RE: Philco 65 paper capacitors - by Radioroslyn - 08-07-2022, 12:01 PM
RE: Philco 65 paper capacitors - by morzh - 08-07-2022, 03:47 PM
RE: Philco 65 paper capacitors - by Radioroslyn - 08-07-2022, 04:33 PM
RE: Philco 65 paper capacitors - by Kestas - 08-07-2022, 04:36 PM
RE: Philco 65 paper capacitors - by Ron Ramirez - 08-07-2022, 06:35 PM
RE: Philco 65 paper capacitors - by morzh - 08-07-2022, 06:55 PM
RE: Philco 65 paper capacitors - by Ron Ramirez - 08-07-2022, 08:12 PM
RE: Philco 65 paper capacitors - by Kestas - 08-08-2022, 08:25 PM
RE: Philco 65 paper capacitors - by Ron Ramirez - 08-08-2022, 08:38 PM
Gloritone 27 Radio
Hello, I sure hope there is someone out there that knows this radio. I am just getting started on scoping out the schema...dconant — 03:36 PM
Philco 49-1040
Really cool old TV Mr. Anderson! Just being complete, clean and unmolested means a lot! I love how the tuner is flipped ...TV MAN — 10:36 AM
I did run into a guy on the FB Philco Radio Enthusiast page who is searching for the output transformer for a 46-480, so...jrblasde — 10:12 PM
I may have just found the IF transformer. There is a person on FB Marketplace who is selling a 46-480 in need of some re...jrblasde — 10:10 PM
Restoring Philco 96
Have just bought this. The field coil tested at 3.18K. The cone has one small tear. I think this is what I need. Not ...morzh — 06:22 PM
91H Code 126 Restore
Well I am making progress with my first Philco.  It took a bit to figure out the on/off/band switch and tone control nei...RealRider — 01:33 PM
Interesting design in that the plate circuits of the first detector and IF stage take full B+ right from the filament of...462ron — 08:44 AM
Hello mike, that is lucky that you were able to do that ! I have one of my radios that the volume control is getting s...radiorich — 12:18 AM
That one cannot be taken apart well. It is riveted. But the domed switch luckily has some spacing (not much and not inte...morzh — 09:44 PM
Hello Mike, that D5 is great for switches and I do the same I will try spraying it through a side hole first before tak...radiorich — 09:38 PM
