Philco 16B restoration
That Sprague "atoms" cap reminds me of some caps that were around when I was a kid in the 60's. It's a little hard to tell from the pic but the ones that were about 1 1/2" x 4" long were 100mfd at 450v. A little over kill for your 16B.
On the code 121's I've been putting Philco spkr plugs/sockets on them. It just make life easier to move it around. On the tombstone (1934) installing the spkr back into the cabinet is little precarious. Having the chassis half out and aligning the edge of the spkr into to cove at the peak cabinet. As the hold down screws are sliding out of the front. It can be a little frustrating.
They are fun sets to work on... Sometimes...
Philco 16B restoration - by morzh - 08-07-2022, 02:27 PM
RE: Philco 16B restoration - by Radioroslyn - 08-07-2022, 06:49 PM
RE: Philco 16B restoration - by morzh - 10-09-2022, 09:11 PM
RE: Philco 16B restoration - by klondike98 - 10-09-2022, 09:38 PM
RE: Philco 16B restoration - by Radioroslyn - 10-09-2022, 10:00 PM
RE: Philco 16B restoration - by morzh - 10-09-2022, 10:16 PM
RE: Philco 16B restoration - by morzh - 10-11-2022, 08:28 PM
RE: Philco 16B restoration - by morzh - 10-15-2022, 09:37 PM
RE: Philco 16B restoration - by morzh - 10-16-2022, 09:52 PM
RE: Philco 16B restoration - by morzh - 10-17-2022, 08:36 PM
RE: Philco 16B restoration - by morzh - 10-19-2022, 09:13 PM
RE: Philco 16B restoration - by morzh - 10-20-2022, 07:51 PM
RE: Philco 16B restoration - by morzh - 10-23-2022, 07:04 PM
RE: Philco 16B restoration - by morzh - 10-26-2022, 02:03 PM
RE: Philco 16B restoration - by Radioroslyn - 10-26-2022, 02:12 PM
RE: Philco 16B restoration - by morzh - 10-26-2022, 10:33 PM
RE: Philco 16B restoration - by radiorich - 10-26-2022, 11:04 PM
RE: Philco 16B restoration - by morzh - 10-27-2022, 07:01 PM
RE: Philco 16B restoration - by morzh - 10-28-2022, 10:05 PM
RE: Philco 16B restoration - by morzh - 12-18-2022, 02:26 PM
RE: Philco 16B restoration - by Paul Philco322 - 12-18-2022, 05:00 PM
RE: Philco 16B restoration - by morzh - 12-18-2022, 05:29 PM
RE: Philco 16B restoration - by morzh - 12-29-2022, 03:58 PM
RE: Philco 16B restoration - by MrFixr55 - 12-29-2022, 07:30 PM
RE: Philco 16B restoration - by morzh - 12-29-2022, 08:27 PM
Philco 91 Tuning Condenser
There are currently 8713 online users. [Complete List]
» 3 Member(s) | 8710 Guest(s)
