Philco model 90 cathereral
...and you have the original looking electrolytics in the back! And the tube shields, that's a plus. Also the power cord and plug. Stuff that often goes missing...the bakelite condensers are half the fun! no problem. Just heat them up a little, push the contents down with a stiff wire, then take out the screw and finish the job. You may have to unsolder a wire or two, but not always.
-Simon
Philco model 90 cathereral - by Dan Walker - 08-11-2022, 08:24 PM
RE: Philco model 90 cathereral - by Radioroslyn - 08-11-2022, 08:51 PM
RE: Philco model 90 cathereral - by Simon Wa3uay - 08-12-2022, 01:19 PM
RE: Philco model 90 cathereral - by rfeenstra - 08-12-2022, 03:28 PM
RE: Philco model 90 cathereral - by radio1 - 08-12-2022, 07:03 PM
RE: Philco model 90 cathereral - by Ron Ramirez - 08-12-2022, 11:40 PM
RE: Philco model 90 cathereral - by Dan Walker - 08-14-2022, 09:03 AM
RE: Philco model 90 cathereral - by Ron Ramirez - 08-14-2022, 10:06 AM
RE: Philco model 90 cathereral - by Dan Walker - 08-14-2022, 10:52 AM
RE: Philco model 90 cathereral - by morzh - 08-14-2022, 07:34 PM
RE: Philco model 90 cathereral - by Dan Walker - 08-14-2022, 08:00 PM
RE: Philco model 90 cathereral - by morzh - 08-14-2022, 08:24 PM
I did run into a guy on the FB Philco Radio Enthusiast page who is searching for the output transformer for a 46-480, so...jrblasde — 10:12 PM
I may have just found the IF transformer. There is a person on FB Marketplace who is selling a 46-480 in need of some re...jrblasde — 10:10 PM
Restoring Philco 96
Have just bought this. The field coil tested at 3.18K. The cone has one small tear. I think this is what I need. Not ...morzh — 06:22 PM
91H Code 126 Restore
Well I am making progress with my first Philco.  It took a bit to figure out the on/off/band switch and tone control nei...RealRider — 01:33 PM
Interesting design in that the plate circuits of the first detector and IF stage take full B+ right from the filament of...462ron — 08:44 AM
Hello mike, that is lucky that you were able to do that ! I have one of my radios that the volume control is getting s...radiorich — 12:18 AM
That one cannot be taken apart well. It is riveted. But the domed switch luckily has some spacing (not much and not inte...morzh — 09:44 PM
Hello Mike, that D5 is great for switches and I do the same I will try spraying it through a side hole first before tak...radiorich — 09:38 PM
Almost decided ot turn it on, but didn't like the power switch being 50 - 100 Ohms, so it is the same exact switch as in...morzh — 08:56 PM
Philco 49-1040
+1 Bob. Yeah, they bought it in 1949 or so, but by 1960, with the CRT starting to dim and after having the set repaired...MrFixr55 — 04:41 PM
There are currently 3674 online users. [Complete List]
» 3 Member(s) | 3671 Guest(s)
