39-116 Restoration
Yes, batterymaker is still around, he's working on a Phillips multiband transistor portable from the 60's, at least in his you tube videos. If you thought a 39-116 was bad underneath take a look at that engineering disaster, the ironic part is that the Phillips tube radios I have encountered are among the better designed and logically laid out of the European radios I have worked on, I don't know what went wrong there. Maybe that's why he hasn't got to your battery yet?
39-116 Restoration - by ipwizard - 05-17-2011, 07:16 PM
RE: 39-116 Restoration - by 78zenithtv - 10-24-2017, 11:22 PM
Re: 39-116 Electronics Restored - by Uffda - 05-17-2011, 08:45 PM
Re: 39-116 Electronics Restored - by w4rtc - 05-17-2011, 10:37 PM
Re: 39-116 Electronics Restored - by TA Forbes - 05-18-2011, 12:04 AM
Re: 39-116 Electronics Restored - by ipwizard - 05-18-2011, 01:23 AM
Re: 39-116 Electronics Restored - by w4rtc - 05-18-2011, 01:04 PM
Re: 39-116 Electronics Restored - by w4rtc - 05-18-2011, 04:35 PM
Re: 39-116 Electronics Restored - by ipwizard - 05-18-2011, 05:14 PM
Re: 39-116 Electronics Restored - by Ron Ramirez - 05-18-2011, 09:53 PM
Re: 39-116 Electronics Restored - by Ron Ramirez - 05-18-2011, 10:01 PM
Re: 39-116 Electronics Restored - by Arran - 05-18-2011, 10:10 PM
Re: 39-116 Restoration - by ipwizard - 05-20-2011, 06:45 PM
The speaker table error?
Philco 70 antenna lead
