Model 118 frozen Bandswitch Help
Mike M,
 I appreciate your help. The switch you pictured is a little different from mine which does have a 2nd piece of wafer material on the back The thing is how do I disassemble the switch? The outside shaft seems to have I don't know a collarwhere it enters the bushing and it does not allow it to be pushed thru to the back. Normally I would expect a c clip between the bushing and the shaft but I don't find one. So I don't see how the shaft can be removed or the bushing removed.
                                                            Henry
Model 118 frozen Bandswitch Help - by radiohenry - 08-03-2022, 02:51 PM
RE: Model 118 frozen Bandswitch Help - by morzh - 08-03-2022, 10:38 PM
RE: Model 118 frozen Bandswitch Help - by David - 08-04-2022, 02:00 PM
RE: Model 118 frozen Bandswitch Help - by Chas - 08-04-2022, 06:00 PM
RE: Model 118 frozen Bandswitch Help - by morzh - 08-04-2022, 06:40 PM
RE: Model 118 frozen Bandswitch Help - by Chas - 08-04-2022, 09:55 PM
RE: Model 118 frozen Bandswitch Help - by morzh - 08-04-2022, 10:49 PM
RE: Model 118 frozen Bandswitch Help - by morzh - 08-05-2022, 10:24 PM
RE: Model 118 frozen Bandswitch Help - by Chas - 08-06-2022, 11:12 AM
RE: Model 118 frozen Bandswitch Help - by GarySP - 08-07-2022, 02:22 PM
RE: Model 118 frozen Bandswitch Help - by GarySP - 08-08-2022, 11:37 AM
RE: Model 118 frozen Bandswitch Help - by Greg - 08-10-2022, 02:54 PM
RE: Model 118 frozen Bandswitch Help - by morzh - 08-13-2022, 10:17 PM
RE: Model 118 frozen Bandswitch Help - by GarySP - 08-14-2022, 08:17 AM
RE: Model 118 frozen Bandswitch Help - by morzh - 08-14-2022, 07:31 PM
RE: Model 118 frozen Bandswitch Help - by radiohenry - 08-14-2022, 09:28 PM
RE: Model 118 frozen Bandswitch Help - by Chas - 08-17-2022, 03:40 PM
I did run into a guy on the FB Philco Radio Enthusiast page who is searching for the output transformer for a 46-480, so...jrblasde — 10:12 PM
I may have just found the IF transformer. There is a person on FB Marketplace who is selling a 46-480 in need of some re...jrblasde — 10:10 PM
Restoring Philco 96
Have just bought this. The field coil tested at 3.18K. The cone has one small tear. I think this is what I need. Not ...morzh — 06:22 PM
91H Code 126 Restore
Well I am making progress with my first Philco.  It took a bit to figure out the on/off/band switch and tone control nei...RealRider — 01:33 PM
Interesting design in that the plate circuits of the first detector and IF stage take full B+ right from the filament of...462ron — 08:44 AM
Hello mike, that is lucky that you were able to do that ! I have one of my radios that the volume control is getting s...radiorich — 12:18 AM
That one cannot be taken apart well. It is riveted. But the domed switch luckily has some spacing (not much and not inte...morzh — 09:44 PM
Hello Mike, that D5 is great for switches and I do the same I will try spraying it through a side hole first before tak...radiorich — 09:38 PM
Almost decided ot turn it on, but didn't like the power switch being 50 - 100 Ohms, so it is the same exact switch as in...morzh — 08:56 PM
Philco 49-1040
+1 Bob. Yeah, they bought it in 1949 or so, but by 1960, with the CRT starting to dim and after having the set repaired...MrFixr55 — 04:41 PM
There are currently 3381 online users. [Complete List]
» 1 Member(s) | 3380 Guest(s)
