116x schematic?
You might also try the official Philco Service Bulletin 222A (also in the library). The Philco Service Bulletins were scanned in higher quality than some of our other documents.
https://philcoradio.com/library/download...20222A.pdf
For my own use I typically to go the Service Bulletin list first - and check our other materials if we don't have one.
https://philcoradio.com/library/index.ph...bulletins/
116x schematic? - by poulsbobill - 08-15-2022, 03:25 PM
RE: 116x schematic? - by RodB - 08-15-2022, 05:00 PM
RE: 116x schematic? - by poulsbobill - 08-15-2022, 08:59 PM
RE: 116x schematic? - by Nathan Slingerland - 08-15-2022, 11:06 PM
RE: 116x schematic? - by RodB - 08-16-2022, 09:54 AM
RE: 116x schematic? - by poulsbobill - 08-16-2022, 11:33 AM
I did run into a guy on the FB Philco Radio Enthusiast page who is searching for the output transformer for a 46-480, so...jrblasde — 10:12 PM
I may have just found the IF transformer. There is a person on FB Marketplace who is selling a 46-480 in need of some re...jrblasde — 10:10 PM
Restoring Philco 96
Have just bought this. The field coil tested at 3.18K. The cone has one small tear. I think this is what I need. Not ...morzh — 06:22 PM
91H Code 126 Restore
Well I am making progress with my first Philco.  It took a bit to figure out the on/off/band switch and tone control nei...RealRider — 01:33 PM
Interesting design in that the plate circuits of the first detector and IF stage take full B+ right from the filament of...462ron — 08:44 AM
Hello mike, that is lucky that you were able to do that ! I have one of my radios that the volume control is getting s...radiorich — 12:18 AM
That one cannot be taken apart well. It is riveted. But the domed switch luckily has some spacing (not much and not inte...morzh — 09:44 PM
Hello Mike, that D5 is great for switches and I do the same I will try spraying it through a side hole first before tak...radiorich — 09:38 PM
Almost decided ot turn it on, but didn't like the power switch being 50 - 100 Ohms, so it is the same exact switch as in...morzh — 08:56 PM
Philco 49-1040
+1 Bob. Yeah, they bought it in 1949 or so, but by 1960, with the CRT starting to dim and after having the set repaired...MrFixr55 — 04:41 PM
