Model 118 frozen Bandswitch Help
#34
Rebuilt a Crosley 02CB for a friend, several years ago. had concentric shafts for band switch and another function (Tuning?) that I can't remember. I could not get the 2 parts loose for love or money, including heating with a torch (plumbing) and quenching with Liquid Wrench at the joints, to no avail. Went scary and whipped out the Dremel and cut a slit in the outer shaft. This did 2 things. Allowed the collar to expand a little and provided a "trench reservoir" for the Liquid Wrench. After another application of heat, I finally was able to free, remove, clean, lube and reassemble. Outer shaft was aluminum (if I remember correctly), inner shaft was brass. Dunno why they seized, no major corrosion, mouse leavings, etc.
While this would be radical surgery (I hear you all cringing!) if this was a Walton, Stratosphere, Scott, etc. (Pick your top of the line radio), it was a Crosley. and that "mod" was nothing compared to the need to completely replace EVERY wire in the chassis along with all the caps and many resistors. Fortunately, a big chassis w/ a lot of triodes instead of multifunction tubes in the AF section) so much room. BTW, dunno if this was a cost savings or what, instead of PP 6V6 or 6F6, this radio had 6AC5s in Class B., very rare in radios of this vintage that were not battery farm sets.
Put in a Radio / Aux sw and different size jacks in an external box (Radio had jumper type phono input terminal board. Owner can actually play his guitar through it not enough gain to overdrive, but that Magnavox speaker IS 80 years old.
Model 118 frozen Bandswitch Help - by radiohenry - 08-03-2022, 02:51 PM
RE: Model 118 frozen Bandswitch Help - by morzh - 08-03-2022, 10:38 PM
RE: Model 118 frozen Bandswitch Help - by David - 08-04-2022, 02:00 PM
RE: Model 118 frozen Bandswitch Help - by Chas - 08-04-2022, 06:00 PM
RE: Model 118 frozen Bandswitch Help - by morzh - 08-04-2022, 06:40 PM
RE: Model 118 frozen Bandswitch Help - by Chas - 08-04-2022, 09:55 PM
RE: Model 118 frozen Bandswitch Help - by morzh - 08-04-2022, 10:49 PM
RE: Model 118 frozen Bandswitch Help - by morzh - 08-05-2022, 10:24 PM
RE: Model 118 frozen Bandswitch Help - by Chas - 08-06-2022, 11:12 AM
RE: Model 118 frozen Bandswitch Help - by GarySP - 08-07-2022, 02:22 PM
RE: Model 118 frozen Bandswitch Help - by GarySP - 08-08-2022, 11:37 AM
RE: Model 118 frozen Bandswitch Help - by Greg - 08-10-2022, 02:54 PM
RE: Model 118 frozen Bandswitch Help - by morzh - 08-13-2022, 10:17 PM
RE: Model 118 frozen Bandswitch Help - by GarySP - 08-14-2022, 08:17 AM
RE: Model 118 frozen Bandswitch Help - by morzh - 08-14-2022, 07:31 PM
RE: Model 118 frozen Bandswitch Help - by MrFixr55 - 08-17-2022, 06:52 AM
RE: Model 118 frozen Bandswitch Help - by Chas - 08-17-2022, 03:40 PM
I did run into a guy on the FB Philco Radio Enthusiast page who is searching for the output transformer for a 46-480, so...jrblasde — 10:12 PM
I may have just found the IF transformer. There is a person on FB Marketplace who is selling a 46-480 in need of some re...jrblasde — 10:10 PM
Restoring Philco 96
Have just bought this. The field coil tested at 3.18K. The cone has one small tear. I think this is what I need. Not ...morzh — 06:22 PM
91H Code 126 Restore
Well I am making progress with my first Philco.  It took a bit to figure out the on/off/band switch and tone control nei...RealRider — 01:33 PM
Interesting design in that the plate circuits of the first detector and IF stage take full B+ right from the filament of...462ron — 08:44 AM
Hello mike, that is lucky that you were able to do that ! I have one of my radios that the volume control is getting s...radiorich — 12:18 AM
That one cannot be taken apart well. It is riveted. But the domed switch luckily has some spacing (not much and not inte...morzh — 09:44 PM
Hello Mike, that D5 is great for switches and I do the same I will try spraying it through a side hole first before tak...radiorich — 09:38 PM
Almost decided ot turn it on, but didn't like the power switch being 50 - 100 Ohms, so it is the same exact switch as in...morzh — 08:56 PM
Philco 49-1040
+1 Bob. Yeah, they bought it in 1949 or so, but by 1960, with the CRT starting to dim and after having the set repaired...MrFixr55 — 04:41 PM
There are currently 3430 online users. [Complete List]
» 2 Member(s) | 3428 Guest(s)
