Philco 19X Coil Question
It would appear that the feedback winding is open which will render the local oscillator inoperable. It's the small winding on the outside of the oscillator coil. Remove that winding, insulator, and discard replace insulator with a replica made from thin plastic. Rewinding requires 38 or 36g wire at about 14t. You can run a needled over the existing winding and count the bumps to ascertain the correct number. Direction is important. Wind it the wrong way around and won't oscillate.
Before you pull the trigger do check the wires going from the winding to the terminals that they go to that winding that is suspect. Since the diagram doesn't list the pin connections vs what winding. I can't make a absolute answer that coil is open but there's a real good chance.
Philco 19X Coil Question - by Phil27 - 08-19-2022, 11:30 AM
RE: Philco 19X Coil Question - by Radioroslyn - 08-19-2022, 03:24 PM
RE: Philco 19X Coil Question - by Phil27 - 08-19-2022, 07:10 PM
RE: Philco 19X Coil Question - by Radioroslyn - 08-19-2022, 11:34 PM
RE: Philco 19X Coil Question - by Phil27 - 08-25-2022, 09:41 PM
RE: Philco 19X Coil Question - by Radioroslyn - 08-25-2022, 11:18 PM
RE: Philco 19X Coil Question - by GarySP - 08-26-2022, 09:19 AM
Interesting design in that the plate circuits of the first detector and IF stage take full B+ right from the filament of...462ron — 08:44 AM
Hello mike, that is lucky that you were able to do that ! I have one of my radios that the volume control is getting s...radiorich — 12:18 AM
That one cannot be taken apart well. It is riveted. But the domed switch luckily has some spacing (not much and not inte...morzh — 09:44 PM
Hello Mike, that D5 is great for switches and I do the same I will try spraying it through a side hole first before tak...radiorich — 09:38 PM
Almost decided ot turn it on, but didn't like the power switch being 50 - 100 Ohms, so it is the same exact switch as in...morzh — 08:56 PM
Philco 49-1040
+1 Bob. Yeah, they bought it in 1949 or so, but by 1960, with the CRT starting to dim and after having the set repaired...MrFixr55 — 04:41 PM
Hi Richard. Yes, we are waiting for warm weather. I have more than a dozen hulls waiting to be painted.RadioSvit — 11:06 AM
Then it is even easier. Yep, my GE guide also says "Silicon".morzh — 09:43 AM
Mike, according to my ECG replacement guide, the AR107 & AR108 both cross reference to a ECG 123A as does a GE-10. T...462ron — 09:41 AM
The 66 Ohm filter in the 1st detector's plate circuit. Look in the early version sch. Here it is, the spiral that ma...morzh — 09:11 AM
There are currently 2630 online users. [Complete List]
» 4 Member(s) | 2626 Guest(s)
AvatarAvatarAvatarAvatar
