New Member with Philco 38-12 open oscillator coil
I am appreciating the helpful responses I have been given so far...on the other hand, I am still looking for information on the second part of my query.  Since 3 of the 4 pins except the wire from the primary coil on pin 2 had broken wires at the solder terminals end with no continuity to any other pin, I am uncertain about how to rewind and connect the secondary coil.  Since the wire connected to pin 2 was one end of the largest winding on the coil I can now infer how to wind this larger primary coil.  As I posted, I am trying to learn if the secondary coil wire connected to pin 4 is also wired so that it terminates at the index mark end of the coil as is the case for pin 2 and does the winding connected to pin 3 terminate at the solder lug end or is it connected the other way from pin 2?
Ernie
RE: New Member with Philco 38-12 open oscillator coil - by eewat - 08-21-2022, 02:39 PM
Morning, Ron! Yep, that’s the Moyer I spoke with. They did say that they researched for any off-brand equivalents but di...jrblasde — 08:51 AM
Joseph, the Moyer Electronics I’m familiar with is in Pottsville, PA. Only a half hour from me. My dad used to to buy fr...462ron — 08:24 AM
Thanks, everyone! I suppose I’ll keep these installed since I have them and they do fit. But moving forward I’ll know th...jrblasde — 07:57 AM
Hello joseph, Here is the one that I use made by Vishay part no. VY2103M59Y5VS63V0. Anyway both Digi-Key and Mouser ca...radiorich — 01:34 AM
Silly me, you are right! I read and wrote nF, but was thinking pF.jrblasde — 10:48 PM
0.01uF and 10nF are the same capacitances :lol: Its the rating. Yours are rated to 500V and the Y2 are up to 300V. Obvi...morzh — 10:41 PM
You’re right, yours are much smaller. I must admit that I ordered these without much regard to size. I ordered them back...jrblasde — 10:29 PM
What should I offer?
Thanks, that makes sense. I searched Hepplewhite on Google, and saw some fancy dining chairs.jrblasde — 10:23 PM
My memory had not failed me when I was writing about those inductances. I found them, both 5.6mH and 10mH, both small ax...morzh — 10:21 PM
Joseph, Yes you could do that too. But why did you choose to buy these conspicuously large capacitors? 10nF Y2 caps sho...morzh — 10:02 PM
There are currently 3352 online users. [Complete List]
» 2 Member(s) | 3350 Guest(s)
