1st IF can cover removal Philco 118 Help
The transformer attaches to the can (cover) by those 2 posts on top.
The can should have posts or clips that protrude through chassis, holding it to the chassis.
To remove the can, you have to detach the transformer (assuming it's still wired) from the can (remove nuts) and the release the can from the chassis (remove nuts or undo clips).
I assume you want to remove the can leaving the transformer in place.
Greg O.
Whitehall, PA
