1st IF can cover removal Philco 118 Help
Yea - I see what you mean. Took a look at a photo of one online.
It doesn't look like the can was ever meant to come off of the chassis.
Why do you want to remove it? To get to the transformer inside? If so...
Looks like the transformer comes out by removing the nuts on top and unscrewing the bolt to the chassis holding a metal tab connected to the bottom of the transformer.
Greg O.
Whitehall, PA
There are currently 10634 online users. [Complete List]
» 2 Member(s) | 10632 Guest(s)
