1st IF can cover removal Philco 118 Help
Terry,
 I removed the back just now and the speaker is an H-13 so that makes me happy. It didn't sound bad  when I had the am on last week.. That makes it worth the price of admission.
        Henry
There are currently 8553 online users. [Complete List]
» 1 Member(s) | 8552 Guest(s)
