Here is the schematic
http://www.nostalgiaair.org/PagesByModel...013588.pdf
Which coil is bad? Voice coil, or field coil?
-Keith
46-1226 - by teamtnt - 05-19-2011, 10:27 PM
Re: 46-1226 - by ipwizard - 05-20-2011, 06:58 PM
Re: 46-1226 - by teamtnt - 05-21-2011, 04:17 AM
Re: 46-1226 - by Arran - 05-22-2011, 12:44 AM
Re: 46-1226 - by teamtnt - 05-22-2011, 12:32 PM
Re: 46-1226 - by codefox1 - 05-22-2011, 02:43 PM
Re: 46-1226 - by Arran - 05-22-2011, 09:43 PM
There are currently 10415 online users. [Complete List]
» 2 Member(s) | 10413 Guest(s)
