38-116 Code 121 vs Code 125 - Long Topic!
Hello, Ed: I have long believed that part of the reason the model 44 performs so well for a mere 6 tube set is the 4-gang tuning capacitor it uses. Therefore it would not suprise me to learn that what you surmise is exactly the case.
Re: 38-116 Code 121 vs Code 125 - Long Topic! - by TA Forbes - 05-20-2011, 08:14 PM
