  • 1 Vote(s) - 1 Average
Philco 46-480 Replacing Field Coil w/ Perm Mag (I know I know)
When sizing up a resistor, keep in mind it has to be large enough to dissipate some serious heat.
RE: Philco 46-480 Replacing Field Coil w/ Perm Mag (I know I know) - by morzh - 09-11-2022, 12:57 PM
There are currently 3694 online users. [Complete List]
» 1 Member(s) | 3693 Guest(s)
