  • 1 Vote(s) - 1 Average
Philco 46-480 Replacing Field Coil w/ Perm Mag (I know I know)
These are the Resistors I got for the project. I figured 50 watts should be good for it, yeah?
RE: Philco 46-480 Replacing Field Coil w/ Perm Mag (I know I know) - by RetroRev - 09-11-2022, 03:58 PM
There are currently 3766 online users. [Complete List]
» 1 Member(s) | 3765 Guest(s)
