84b Power Transformer
Wouldn't be too concerns about the heater windings. If you are going to have bad ones the HV is the 1st suspect and the primary is the 2nd. In Philco set the pt are pretty stout. when you take the chassis out of the cabinet and there's a big gob of wax stuck to the cabinet that's the time to be worry about bad a pt. Most of the 84's have some other tricks up their power cords which we here on the Phorum can guide you thru if you like.
84b Power Transformer - by percyjd - 09-17-2022, 06:20 PM
RE: 84b Power Transformer - by Radioroslyn - 09-17-2022, 06:37 PM
RE: 84b Power Transformer - by percyjd - 09-17-2022, 06:45 PM
RE: 84b Power Transformer - by Simon Wa3uay - 09-17-2022, 06:59 PM
RE: 84b Power Transformer - by Radioroslyn - 09-17-2022, 07:08 PM
RE: 84b Power Transformer - by percyjd - 09-17-2022, 07:29 PM
RE: 84b Power Transformer - by Radioroslyn - 09-17-2022, 08:18 PM
Mike; Where was this RF choke located? I remember seeing on a few sets that had detector-amplifiers ahead of the powe...Arran — 02:29 AM
Thank you very much. I'll let you know how it goes.R3Sons — 11:00 PM
Hello mike, Nice job hopefully it works and I am sure it will. Sincerely Richardradiorich — 09:15 PM
Hello Peter, I am glad you got the radios and I too have that same zenith in my collection ! I am also waiting for the...radiorich — 08:52 PM
So, I sat down, and first tried 40 AWG wire. It broke quickly. I retook diameter: this one was 0.05mm whereas the one I ...morzh — 08:24 PM
This is the replacement guide for transistors by GE parts. So, GE-3 is your power replacement for AR14 Just ...morzh — 04:57 PM
Philco 91 Restore Code ??
How do I know if AVC is OK? For the compensator cap I settled on 330pf. Its much closer now and close enough for me. I ...dconant — 04:46 PM
If the small signal ones, take any Ge transistor with unity gain good enough and Vce max 30 or so V. For the output....y...morzh — 03:43 PM
Yes, Michael. This winter I repaired this Westinghouse, RCA 121 and Zenit 5S29. All that remains is to veneer the Zenit ...RadioSvit — 03:28 PM
Thank you. I have one board completely de-populated. Just looking for the correct values. I'll let you know. Still h...R3Sons — 03:13 PM
