  • 1 Vote(s) - 1 Average
Philco 46-480 Replacing Field Coil w/ Perm Mag (I know I know)
Warning: Don't use DeoxIT on volume or tone controls. Use Caig FaderLube instead. DeoxIT can damage the old, thin, fragile carbon strips of potentiometers (i.e. volume and tone controls).
Loctal tube socket contacts can be cleaned with one of those tiny brushes designed for use between one's teeth, sprayed liberally with DeoxIT (don't use that brush on your teeth afterwards Icon_eek ). DeoxIT can also be used on switches without worry.
RE: Philco 46-480 Replacing Field Coil w/ Perm Mag (I know I know) - by Ron Ramirez - 09-19-2022, 09:47 PM
There are currently 9898 online users. [Complete List]
» 1 Member(s) | 9897 Guest(s)
