Philco 42-380
Hi
  I just discovered that some of my wires are broken as well as more than a few of the resistors.
Can any one direct me to where one might go to get wiring as well as resistors. I guess I should have known that I would most likely have to do that.
1942-380 power cord - by Papa1 - 08-31-2022, 06:10 PM
RE: 1942-380 power cord - by klondike98 - 08-31-2022, 07:06 PM
RE: 1942-380 power cord - by Papa1 - 08-31-2022, 08:40 PM
RE: 1942-380 power cord - by GarySP - 09-02-2022, 07:33 AM
RE: Philco 42-380 - by admin - 09-21-2022, 11:41 AM
Capacitors - by Papa1 - 09-19-2022, 02:57 PM
RE: Capacitors - by Radioroslyn - 09-19-2022, 06:03 PM
Wiring - by Papa1 - 09-20-2022, 10:41 PM
RE: Wiring - by klondike98 - 09-20-2022, 11:28 PM
RE: Wiring - by Radioroslyn - 09-21-2022, 09:08 AM
Thank you very much. I'll let you know how it goes.R3Sons — 11:00 PM
Hello mike, Nice job hopefully it works and I am sure it will. Sincerely Richardradiorich — 09:15 PM
Hello Peter, I am glad you got the radios and I too have that same zenith in my collection ! I am also waiting for the...radiorich — 08:52 PM
So, I sat down, and first tried 40 AWG wire. It broke quickly. I retook diameter: this one was 0.05mm whereas the one I ...morzh — 08:24 PM
This is the replacement guide for transistors by GE parts. So, GE-3 is your power replacement for AR14 Just ...morzh — 04:57 PM
Philco 91 Restore Code ??
How do I know if AVC is OK? For the compensator cap I settled on 330pf. Its much closer now and close enough for me. I ...dconant — 04:46 PM
If the small signal ones, take any Ge transistor with unity gain good enough and Vce max 30 or so V. For the output....y...morzh — 03:43 PM
Yes, Michael. This winter I repaired this Westinghouse, RCA 121 and Zenit 5S29. All that remains is to veneer the Zenit ...RadioSvit — 03:28 PM
Thank you. I have one board completely de-populated. Just looking for the correct values. I'll let you know. Still h...R3Sons — 03:13 PM
Is this the one from the Fall Kutztown 2023?morzh — 02:59 PM
