  • 1 Vote(s) - 1 Average
Philco 46-480 Replacing Field Coil w/ Perm Mag (I know I know)
Oh yeah! I know first hand how spicy this thing can be! Nearly gave myself a perm the other day checking voltages xD Ain't the first and, unfortunately, probably won't be the last. I would swear I was a lightning rod in a past life ?
As for the rest of it, hmm.. Well about 80% made its way through. Nothing that a little Googling of the jargon won't clear up though.
I -do- have a signal generator.. Kind of.. It's on time out at the shop currently for letting its magic smoke out a little after a co-worker "fixed" something on it. Still not sure what exactly to be honest. I'll pull it out tomorrow and see if it's a quick fix or a doorstop.
-Rev
RE: Philco 46-480 Replacing Field Coil w/ Perm Mag (I know I know) - by RetroRev - 09-21-2022, 11:50 PM
There are currently 9772 online users. [Complete List]
» 1 Member(s) | 9771 Guest(s)
