  • 1 Vote(s) - 1 Average
Philco 46-480 Replacing Field Coil w/ Perm Mag (I know I know)
#34
Wrong. That looks more suited for TV and (possibly) FM work.
If a signal generator for vintage radios is what you are looking for, then what you need is something that will output amplitude modulated (AM) signals from the IF range of your radio (around 450-455 kHz) up to around 30 MHz.
RE: Philco 46-480 Replacing Field Coil w/ Perm Mag (I know I know) - by Ron Ramirez - 09-24-2022, 02:14 PM
