New Member with Philco 38-12 open oscillator coil
    Hello Ernie, here is a picture/diagram I drew of the oscillator coil in my 38-12. I carefully unwound the secondary and got 1 continuous piece of wire with no breaks. It measured 1.5 ohms; this is why I believe the schematic is incorrect as it says 3.5 ohms. Maybe when the schematic was printed, someone put the wrong number in. Just a suggestion. The original wire measured 1.5 ohms so I rewound using 34 guage wire and it measures 1.6 ohms; almost like the original. Hope this picture helps.
RE: New Member with Philco 38-12 open oscillator coil - by Tubeglow20 - 09-25-2022, 01:11 PM
Hello joseph, Here is the one that I use made by Vishay part no. VY2103M59Y5VS63V0. Anyway both Digi-Key and Mouser ca...radiorich — 01:34 AM
Silly me, you are right! I read and wrote nF, but was thinking pF.jrblasde — 10:48 PM
0.01uF and 10nF are the same capacitances :lol: Its the rating. Yours are rated to 500V and the Y2 are up to 300V. Obvi...morzh — 10:41 PM
You’re right, yours are much smaller. I must admit that I ordered these without much regard to size. I ordered them back...jrblasde — 10:29 PM
What should I offer?
Thanks, that makes sense. I searched Hepplewhite on Google, and saw some fancy dining chairs.jrblasde — 10:23 PM
My memory had not failed me when I was writing about those inductances. I found them, both 5.6mH and 10mH, both small ax...morzh — 10:21 PM
Joseph, Yes you could do that too. But why did you choose to buy these conspicuously large capacitors? 10nF Y2 caps sho...morzh — 10:02 PM
Thomas Sheraton gave his name to the style. That is others in 19 century took his name and assigned it to the style. G...morzh — 09:59 PM
Excellent point! Thank you, sir.jrblasde — 09:58 PM
Hello Joseph, That looks great only thing I would make sure is that screw has good clean area where it contacts the gr...radiorich — 09:50 PM
