Need help identifying a Philco
Hi Carl
I only had enough time to look at the first picture, and that chassis is a Model 38-15.
Need help identifying a Philco - by Guest - 05-10-2006, 11:20 PM
[No subject] - by Guest - 05-12-2006, 12:31 AM
[No subject] - by Ron Ramirez - 05-12-2006, 06:56 AM
[No subject] - by Guest - 05-12-2006, 07:54 AM
[No subject] - by Guest - 05-14-2006, 09:33 PM
[No subject] - by Terry Judkins - 05-15-2006, 12:04 AM
Philco 91 Tuning Condenser
