Philco 90 crackling
Thanks for your ideas. There's nothing new in the house to cause the crackling, as none of my other radios do it. I neglected to mention I did try several different tubes in each socket so I eliminated that possibility. However when I pulled the chassis, I heard something rattle within the tuner. So I turned the chassis upside down and out popped a fossilized black piece of grommet. I wiggled on the tuning capacitor and sure enough it's loose. So I spent the night making a wiring diagram (7 wires to the tuner and 2 to the light bulb) and will remove the tuner tomorrow and replace the grommets. While I have it out I'm going to run it through my ultrasonic cleaner. I can see the mica trimmers are very dirty and there's still a lot of dirt within the tuner itself. The one mystery I have yet to solve is how to remove the dial scale from the tuner. I see a set screw but there must be something else holding it to the shaft.
Philco 90 crackling - by NostalgiaRadioTime - 09-27-2022, 08:26 PM
RE: Philco 90 crackling - by radio1 - 09-27-2022, 08:40 PM
RE: Philco 90 crackling - by David - 09-27-2022, 08:42 PM
RE: Philco 90 crackling - by morzh - 09-27-2022, 10:19 PM
RE: Philco 90 crackling - by GarySP - 09-27-2022, 10:30 PM
RE: Philco 90 crackling - by NostalgiaRadioTime - 09-27-2022, 10:43 PM
RE: Philco 90 crackling - by radiorich - 09-28-2022, 12:30 AM
RE: Philco 90 crackling - by morzh - 09-28-2022, 10:32 AM
RE: Philco 90 crackling - by NostalgiaRadioTime - 09-28-2022, 07:49 PM
RE: Philco 90 crackling - by Paul Philco322 - 09-28-2022, 08:49 PM
RE: Philco 90 crackling - by radiorich - 09-28-2022, 09:52 PM
RE: Philco 90 crackling - by morzh - 09-29-2022, 08:31 PM
RE: Philco 90 crackling - by radiorich - 09-30-2022, 09:15 AM
RE: Philco 90 crackling - by radio1 - 12-17-2022, 08:14 PM
RE: Philco 90 crackling - by NostalgiaRadioTime - 12-18-2022, 01:49 AM
RE: Philco 90 crackling - by radiorich - 12-18-2022, 03:41 AM
RE: Philco 90 crackling - by rghines1 - 12-20-2022, 11:11 AM
RE: Philco 90 crackling - by NostalgiaRadioTime - 12-21-2022, 02:32 AM
