Philco 90 crackling
It is rare that I skip full removing of the tuning cap and soaking and washing it in soapy water with soft long paintbrush, going between all vanes.
One radio I skipped it with is my Zenith 9-S-262 console, and even though it tunes fine, it really crackles when being tuned. One day I will take care of it.
Philco 90 crackling - by NostalgiaRadioTime - 09-27-2022, 08:26 PM
RE: Philco 90 crackling - by radio1 - 09-27-2022, 08:40 PM
RE: Philco 90 crackling - by David - 09-27-2022, 08:42 PM
RE: Philco 90 crackling - by morzh - 09-27-2022, 10:19 PM
RE: Philco 90 crackling - by GarySP - 09-27-2022, 10:30 PM
RE: Philco 90 crackling - by NostalgiaRadioTime - 09-27-2022, 10:43 PM
RE: Philco 90 crackling - by radiorich - 09-28-2022, 12:30 AM
RE: Philco 90 crackling - by morzh - 09-28-2022, 10:32 AM
RE: Philco 90 crackling - by NostalgiaRadioTime - 09-28-2022, 07:49 PM
RE: Philco 90 crackling - by Paul Philco322 - 09-28-2022, 08:49 PM
RE: Philco 90 crackling - by radiorich - 09-28-2022, 09:52 PM
RE: Philco 90 crackling - by morzh - 09-29-2022, 08:31 PM
RE: Philco 90 crackling - by radiorich - 09-30-2022, 09:15 AM
RE: Philco 90 crackling - by radio1 - 12-17-2022, 08:14 PM
RE: Philco 90 crackling - by NostalgiaRadioTime - 12-18-2022, 01:49 AM
RE: Philco 90 crackling - by radiorich - 12-18-2022, 03:41 AM
RE: Philco 90 crackling - by rghines1 - 12-20-2022, 11:11 AM
RE: Philco 90 crackling - by NostalgiaRadioTime - 12-21-2022, 02:32 AM
Philco 91 Tuning Condenser
There are currently 8748 online users. [Complete List]
» 2 Member(s) | 8746 Guest(s)
