  • 1 Vote(s) - 1 Average
Philco 46-480 Replacing Field Coil w/ Perm Mag (I know I know)
#38
Whelp still looking for a proper signal generator locally, but after doing all the tests I can without one, I've still got nada from the radio. Not even static while tuning or anything short of a small pop when switching bands, so I'm leaning towards this thing either being dead, or improperly wired somewhere that I'm just not seeing..
RE: Philco 46-480 Replacing Field Coil w/ Perm Mag (I know I know) - by RetroRev - 10-02-2022, 11:48 AM
There are currently 3936 online users. [Complete List]
» 1 Member(s) | 3935 Guest(s)
